Berlingo 2001 dw8 1.9 will not stat
Hi all
 My problems all started about 2 weeks ago van was sent in for a valet ... van ended up back at my house on a tow truck lol
will turn over but will not start also when ignition  Is on no glow plug light comes on can get van running on easy start but it runs like a pig due to the fuel pump not retarding or advancing
when started temp or rev counter does not work
 Pluged in autel fault for no communication to engine ecu  suspect water damage
So i went and bought a damage 2001 same shape  van only rear end damage van starts and run fine  I transferred bsi engine ecu key glowplug relay  and dash from damaged van to my own
  Glow plugs all new in my own van about 3 months ago
My own van still same fault and no glow plug light on dash with ecus changed over
 Any ideas or has anyone  any wiring digrams
Any help would be great
maybe change the engine bay fuse box
Ok will try that next
What engine is it? That would help for a start? Guessing dw8 with the little simple ecu on the strut top? It’s could be full of water, I wouldn’t go spending money on anything without doing some simple diagnostics first with a multimeter and some wiring diagrams... the simple ecu will be easy to check for power supply’s and earths
[-] The following 1 user says Thank You to dumdum for this post:
  • Art b
I would be tempted to try the earthing on the vehicle, if you valeter as been busy with the pressure washer my thoughts would be wet or now rusty earths
[-] The following 1 user says Thank You to 1961ed1961 for this post:
  • Art b
Today 03:36 PM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
