  • 10 Vote(s) - 1.8 Average
MK3 FRONT BRAKES
Suspect the o/s front disc pads are not freeing off properly as I am getting an intermittent binding noise and the disc is getting rather hot.
No signs of a leak and B/fluid level is okay.
woodshaper
Sole Member and President for LIFE!
Not had anything noticable on mine. But on my ZX sticking calipers were a problem, and I was told it was a common issue with citroens. But that was a car from 15 years ago. Surely they've got better since then.
The Bus II: 2019 XL Flair 1.2
I have looked on the Forum and found the *same fault reported on the MK2's caused by a faulty Valve on the Servo/faulty Servo, could just be a coincidence of cause it may well be something else?
Taking it into Garage On Monday, to a small specialist Citroen/Renault place with people who know what they are doing. (proper Mechanics)
Hopefully whatever is wrong won't cost me an arm and a leg!
Covered over 61,000+ miles so far, other than the ********* Tyre Wear and Timing Belt problems have also replaced the Clutch and Disc/pads, My Berli is running well and I STILL LIKE IT!
Rattles, did I mention rattles...................................................................................................................................and not finding/having enough room to park it round here:S
woodshaper
*This Forum is brilliant Andre:thumbsup:
(26-01-2012, 05:43 PM)woodshaper Wrote:  Suspect the o/s front disc pads are not freeing off properly as I am getting an intermittent binding noise and the disc is getting rather hot.
woodshaper
Hi woodshaper, just on with my brakes, same thing but mk2, right front stuck on, the pad material as come away from its backing,( bosch brakes) I suppose this is with getting very hot. I did notice that when braking hard the back of the van sat down abit, rear brakes getting to much pressure, pressure valve on rear could have sized up, it a tin of wd40 and a hammer job to get the arm working, will let you know the outcome, am doing it today.:brickwall:
[-] The following 1 user says Thank You to bechstein for this post:
  • woodshaper
Best of luck bechstein! My pads sometimes free off and sometimes don't??????????????????????????????????
woodshaper
After stripping and cleaning the corrosion off both front brakes, problem solved!
woodshaper
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
