Threads: 2
Thanks Received: 2 in 2 posts
06-06-2022, 08:19 PM
(This post was last modified: 07-06-2022, 06:54 PM by gpowens1.)
Hi my 2015 berlingo enterprise has airbag light on displays seat belt pretension fault?
Anyone any idea what could be wrong I don’t see any pretensioner near the seat belt socket connector?
Threads: 52
Thanks Given: 145
7
The belt pretensioner is in the belt reel inside the b-pillar trim.
Matt
2019 Multispace BlueHDi 100 Flair Nimbus Grey Met
Threads: 2
There is no pretensioner on it only the driver seat belt bucket pocket has a wire into it but that’s for the dash warning seat belt symbol.the 2 passenger seat belt are just the standard with no wiring.
I forgot to say airbag light is on and fault code begins with
Airbag or seat belt pretensioner fault
Threads: 75
Thanks Received: 1,282 in 1,134 posts
Thanks Given: 223
162
Must be the airbag circuit then! Likely the clockspring ribbon in the steering wheel or the comms unit which the wires pass through. The vans only have a drivers wheel airbag so that's where to start looking. Probably a broken connection on a wire or a crack in the clockspring ribbon.
