  • 15 Vote(s) - 3.33 Average
Glow plugs
Simple question.
Hopefully simple answer...
How easy is it to renew the glow plugs?
Has anyone done this job?
If it is straightforward, may do a tutorial for the Forum.:thumbsup:
In the world of glow plugs, do you get what you pay for like most things?
£29.99 on ebay, or £46 for Bosch.
http://www.ebay.co.uk/itm/CITROEN-C1-C2-...4ab17b364d
Is fairly straightforward, are yours knackered then?
You get what you pay for yes... Beru, NGK, or Bosch are all good, but is always wise to check glow plugs before fitment as they have been known to be duff, fresh from the box!!
My engine runs slightly 'uneven' and 'lumpy' after starting from cold for short time. It is fine when starting from warm.
As the glow plugs are not only used for starting, but warming the engine after starting, my local garage has pointed out this could be the problem.
Will test them before changing, just wanted to know if it is a DIY job.
Easy on the 2.0 - don't know about yours
Not in the best place.
Back of the engine under air filter housing.
(23-03-2012, 05:35 PM)j90xxx Wrote:  My engine runs slightly 'uneven' and 'lumpy' after starting from cold for short time. It is fine when starting from warm.
Piece of cake on the 2.0HDi, I did mine the other week. Had to loosen and remove the rail that holds the wiring out of the way and use a deep-reach socket and extension, but not difficult at all.
By a massive stroke of luck, I got Citroen original glowplugs that are £21 EACH at the dealer, for £19.99 for all 4 off ebay :-)
If you can post a pic of your engine bay myself or someone else will be able to give you a pointer or two..
[-] The following 1 user says Thank You to mikep1973 for this post:
  • j90xxx
Today 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
