  • 11 Vote(s) - 2.82 Average
Timing Belt Cover
Hi all,
OK, so I've now changed my 2.0HDi Bingo for a 2.0HDi Dispatch....and I was reassured that I would still be welcome here, so here I am! :lol:
Anyway, I've just managed to give it a good check over today and am very pleased with my purchase, however, one thing that is a bit of a concern is that the timing belt is very exposed.....:O Should it have some kind of casing or cover to protect it?
The engine itself is nowhere near as protected as what my Bingo one was with no cover at all.
(01-01-2013, 07:49 PM)Merlecollins Wrote:  Hi all,
Yes the belt should have a full 3 piece cover on it, the same as on the previous Berlingo you had. You best get yourself a replacement ASAP .
This is for the dispatch 2.0Hdi 136 engine. If yours is a newer version (Mk3) etc it will probably be different. Let us know and I'll dig it out if it's of any use. Confusedalut:
[Image: fmkjt.jpg]
[-] The following 2 users say Thank You to Rustscrat for this post:
  • Merlecollins, ron
(02-01-2013, 11:31 AM)Rustscrat Wrote:  This is for the dispatch 2.0Hdi 136 engine. If yours is a newer version (Mk3) etc it will probably be different. Let us know and I'll dig it out if it's of any use. Confusedalut:
[Image: fmkjt.jpg]
Thanks Rustscrat :thumbsup:
Mine is a 2004 model version. It is a 53 plate but is the facelift 2004 model.
The VIn is VF7BYRHZB86080587
Cheers mate Wink
This is the one listed for yours. The part No's are - 1 = 0320 N5,
2 = 0320 N6, 3 = 0320 S7.
These are the same as the 2.0hdi Berlingo engine.
Good luck. Confusedalut:
[Image: w06cs6.jpg]
  • Ol'Jeffers, ron
Yesterday 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
