  • 5 Vote(s) - 1.4 Average
diesel pump primer
    used this when i changed the diesel filter to prime filter , has connections or can be permantly fitted , fittings can be used either end or use 9mm pipe also included , saves that not starting thing when the filter is changed , £12 posted ppal as gift or add £2 to cover fees , or postall order.
2010 1.6 hdi 110bhp XTR
My 2.0 hdi has a priming pump already in line to prime the filter.
(23-10-2013, 06:11 PM)steve valentine Wrote:  My 2.0 hdi has a priming pump already in line to prime the filter.
yep so has mine but they are poor , i fitted this on the out flow from the filter housing and it realy drew the diesel through , and it has a one way valve fitted so it cant flow back again . factory ones dont , and fuel can drain back to the tank hence the problems .
Ive also fitted a one way valve.
bump for this item .
(30-10-2013, 06:28 PM)rdfb2 Wrote:  bump for this item .
new year bump
I bought one of these for a mates Peugeot, not sure if he's fitted it yet?
Has built in non return, I think. No idea if it cured his problem. Confusedcratch:
http://www.ebay.co.uk/itm/8mm-Fuel-Prime...53e89536bb
Today 11:13 AM
Today 09:14 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
