  • 2 Vote(s) - 2 Average
Additional heating resistor
Question
Is there such a thing as an additional 1kw heater resistor that can just be enabled in software, that is fitted to the MK3 berlingo's?
I'm picking up a new XTR in a few weeks, that will have automatic climate A/C.
Does anyone know if one is even fitted ? Or can be added ?
I would like to enable it for the winter months.
Failing that I'll look at the webasto unit, but they seem excessive for the UK.
t1ny
it is fitted to cars with diesel engines. its automaticly on if outside temperature is below 10C and motor temperature is below 70C.. thats it.
[-] The following 1 user says Thank You to templ for this post:
  • T1NY
I still don't understand what this is about, can somebody explain?
Modern Diesel engines are so efficient that they don't waste much energy/fuel as heat.
So they take a long time to warm up from cold, hence the need for additional heating.
The Webasto units are small diesel powered additional pre heaters that can be used to warm a car up and defrost it, (on a timer or remote control) so the vehicle is warm and defrosted when it's needed.
They are mostly used in countries much colder than England.
T1ny
[-] The following 1 user says Thank You to T1NY for this post:
  • Opensauce
I don't know if they are still around, but Kenlowe, the people who used to sell electric radiator fans in the days before they were commonplace, used to make a 3kw electric pre-heater that you plumb into the appropriate hose on the cooling system. This is controlled by a clock timer to ensure your engine is nice n warm before you drive off. Had one fitted to our Land Rover years ago. Not cheap, but cheaper than the diesel alternative. Ideally the plug that powers it should be situated so that it unplugs itself should you happen to forget to unplug before driving off. Failure to observe this warning will result in "the dissipation of energy in the form of heat and light" as my old science master used to say. My wife knows this to be true.
:eek:
Don´t know if these guys sell in the UK, but they are fitted as standard to most petrol cars in Finland
http://www.defa.com/en/automotive/warmup/
Warms the engine before starting as well as the interior Smile
My car also came with a winter shield for the radiator, which helps the engine run at a higher temp. and is a bit tidier than a bit of cardboard Smile
triangle light
Last Post: norm1
Yesterday 08:55 AM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
