  • 4 Vote(s) - 3.5 Average
2009 1.6HDi 75, won't turn over or start
Have owned our 2009 Bermingo 1.6HDi 75 for about 7 or 8 months now, and this is the first serious problem.
I'd been diving the car all morning. About 20 miles.
Dropped home for something and was in the house for about 10 minutes. Came out and the car won't start. Turn the key and nothing happens. Battery is fine, but starter doesn't even turn over.
Anyone got any ideas?
Something similar happened to me once, about 3 weeks ago with it. Turned the key and nothing happened, but I just tried again and on the third go it started up, business as usual.
I'm guessing some electrical issue, maybe a loose connection, but, could it be something more serious?
Any help gratefully received.
Thanks.
If you're getting all the correct dash lights when you switch on,
it could be something as simple as a starter relay but it's dangerous and sometimes
expensive to make assumptions as this fault could be due to a number of things.
Start with the simple stuff. Re-check your battery connections etc.
Get battery checked out , a "dead" battery can show 12Volts and dash lights but not enough amps to start.
As ol Jeffers says you can waste lots of money on guessing , simple things first
Jon
1st step is to check battery, as said
Berlingo starters on the MK3 go through a fuse in the underbonnet box, when the starter fails, or gets tired, they often blow the fuse. My guess is it ultimately needs a starter (they fail quite often), but a fuse may get it going once or twice more.
I'd thought that 20A fuse blowing regularly was a sign of the fuse outfeed contact becoming higher resistance than designed, with a net increase in current draw.
Good point addo.
Its always worth looking at cables and terminals for corrosion and being loose , a good source of resistance.
Worth a clean up and tighten before going further.
Jon
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
