11-06-2014, 10:54 PM
(This post was last modified: 11-06-2014, 10:55 PM by billslingo.)
Hello all,
I've just bought my first Berlingo, a Mk2 08 with 95k on the clock. It drives well but I soon noticed a smell of exhaust fumes in the cab. I came across this forum and searched around for some advice and came across a post by Polar which described the leaking injector issue.
I got the bonnet up and had a listen and could clearly hear a loud chuffing around the area of injector No4. Lifting the plastic top cover I could see the tell tale wetness around the base of injecto No4. I disconnected the injector cables and lifted the wiring loom across the top of the injectors, I managed to get a 7mm ball ended hex key socket onto the front and rear injector nuts and got a good 3/4 of a turn on each one. I'm sure I felt a slight click, maybe the injector had partially lifted but I couldn't be sure.
Because I have only just got the van I had no idea how long this issue had gone on for so I followed other advice and removed the servo vacuum pump to check for signs of carbonised oil on the filter gauze (photo)
The filter looks remarkably clean so I'm confident that I've caught this before the oil has become contaminated.
Running the engine afterwards the chuffing had stopped and the tick over had improved, I hadn't thought it was that bad but it sounded even better. The smell of fumes in the cab has improved but I wouldn't say that they have gone completely. It may take time for the residue on the engine to burn off.
I would appreciate some advice on the following:
Should I also pull the turbo oil feed pipe and check it for evidence of carbonised oil etc?
Should I change the oil, the dealer claims to have done it but who knows what they used and whatever it was it already looks very black.
Should I remove the gauze filter from the turbo oil feed pipe for good measure?
Any recommendations on oil types, Total oil isn't that readily available around me so any advice on alternatives would be good.
I'm well aware, due to the posts on this forum, of the consequences for the turbo so I'm determined to get on top of this small issue before it turns into a disaster.
Any advice would be welcome and I will keep the forum posted of my progress with this.
Cheers
Bill
Cheers
Bill
cratch:
