  • 22 Vote(s) - 2.95 Average
[Brakes] Rear Drum removal
Hi guys, Just doing a bit of maintenance to the old girl before the summer here kicks in. Tried to remove the rear brake drum to inspect the shoes but can I get it off? Rhetorical question! Am I missing a trick here? Usually mild persuasion does the trick....is there a hidden screw or bolt? I have taken the small hex out so that is not the problem.
Any ideas or just use a bit more muscle!! :brickwall:
El Berlingo
Bit more gentle persuasion with a bar will do it! You get a lip on the back edge of the drum that gets caught on the shoes, the shoes will move with enough force. Remember to grind the lip of before you re- fit the drums.
[-] The following 1 user says Thank You to duamoHDI for this post:
  • El Berlingo
Hi mate,
Thought that was the case. I needed to check as it sometimes happens that there is some small difference, from one to another, when removing. Will get back on the task!
Cheers,
El Berlingo
(05-03-2012, 07:30 AM)El Berlingo Wrote:  Hi mate,
Cheers,
El Berlingo
Follow this link http://www.berlingoforum.co.uk/forumdisplay.php?fid=12
Download M59 Manual and open section " Removing - refitting : Rear brake shoes"
In other sections of download there is info on Shoe /Drum wear limits
2003 Citroën Berlingo 2.0HDi Multispace Desire
[-] The following 1 user says Thank You to BlueBlingo for this post:
  • El Berlingo
Last Post: tdonbay
Today 05:44 PM
Bolt torque settings
Today 05:42 PM
Last Post: AlRamsay
Today 05:19 PM
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Today 10:59 AM
Last Post: Wightlingo
Today 07:56 AM
Today 06:51 AM
Last Post: saskak
Yesterday 07:30 PM
12-05-2024 11:38 PM
