Rear hub nut torque setting
Threads: 26
Thanks Received: 29 in 14 posts
Thanks Given: 14
Hi all,
I'm in the process of replacing the rear brake drums and have been checking the torque setting for the hub (stub) nut. Citroen specs. state 2,5m.da N. This, I think, means 25 N (2,5 being one tenth). This, does not seem correct. It seems rather insufficient to me. Am I wrong (a very great possibility)? Or, better still, does anyone have the correct torque setting (s) at hand? The figure of 25 N also seems low based on the fact that most torque wrenches for general use only start at around 25/27 N. This means that the wrench would be at its most minimum setting (not advisable) or of no use at all (unless, of course, you have a nice selection of different torque wrenches!).
Any advice (even if it makes me look daft) would be much appreciated. I'm happy to wrong rather than the wheel, literally, coming off!
As always, best regards,
El Berlingo
Threads: 26
Thanks Given: 14
Hi again,
Just looked at some pictures online and the drum seems to come off without removing hub nut! Confused.com now! I seem to recall that the hub nut needed to be removed!
Very confused!
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
The drum is held on with two little locating screws. The hub should not be disturbed unless you are replacing it complete with bearings. The nut is 203 lb ft with separate thrust washer or 185 with integral washer.
Threads: 26
Thanks Given: 14
Hi ffrenchie,
Thanks for the reply. So, no need to touch hub nut then. Fine, so I don't need to worry about the torque settings any more!
Best regards,
Threads: 61
Thanks Received: 699 in 597 posts
Thanks Given: 192
45
New drums then I'd imagine you are fitting new shoes ?? If so then remove / repair one side at side at a time and take a photograph before stripping down as it is easy to forget which bit goes where ....... no prizes for having a good memory !
Serieal Berlingo owner
Threads: 26
Thanks Given: 14
09-12-2016, 08:11 AM
(This post was last modified: 09-12-2016, 08:12 AM by El Berlingo.)
IHi Geoff,
Correct, and always have the IPhone to record what and where things come from! Learnt the hard way!
However, may need to take her in as I tried for nearly two hours to remove brake drum which just will not budge. I don't have a puller so I'm stuck!
Thanks for input,appreciated.
El Berlingo
Threads: 8
Thanks Received: 493 in 443 posts
Thanks Given: 298
29
Did you get the small screws out that hold the drum to the hub?
Can you not wind back the adjusters through one of the wheel bolt holes?
http://www.berlingoforum.co.uk/thread-3686.html
Threads: 29
Thanks Given: 67
20
09-12-2016, 09:30 AM
(This post was last modified: 09-12-2016, 09:40 AM by ffrenchie.)
You need a 1.5lb hammer and thrash round the outside of the drum to loosen the shoes grip on the inside. Two screwdrivers will pry the drum over the shoe or get a bigger hammer and smash the drum, if you are fitting new ones they are scrap anyway. Get mediaeval on it man. (Wear gloves and glasses while you do this, safety first at all times )
Threads: 121
Thanks Given: 248
34
If the drum will turn without the handbrake on (you did release the handbrake?) then it's not the shoes holding the drum at this stage. The drum is probably rusted to the stub axle. As mentioned above, some brute force will break the grip of what's holding the drum to the stub axle. If you hit the front face of the drum around the edges, it should force the drum diagonally. If you're replacing the shoes, some penetrating oil in through the wheel bolts may help.
Another option will be to undo that big nut and take the whole thing off together, if you do that, you can soak both parts from the inside and apply heat.
The garage will probably do the same thing, but with a bigger hammer.
Threads: 26
Thanks Given: 14
09-12-2016, 11:04 AM
Hi all,
Thanks for advice and replies. Yes, two small screws removed and handbrake off (front wheels chocked). Various sized hammers employed with various screwdrivers and implements. Still no joy. I'm trying to avoid taking off the main hub nut as I seem to have 'lost' (someone borrowed it and failed to return it ) my torque wrench needed to refit. Wife, who is an ex East German wrestler, has also given it some stick but still not budging . I will try again (try the adjusters) and see how it goes....I'm not hopeful!
Just for a change its pouring with rain here (sunny Spain) so holding up proceedings somewhat!
Cheers, El Berlingo
ABS light, No Speedo, Loss of Power. Can anyone ...
Last Post: ThomasTheTMC
Today 08:31 PM
Very brief warning light
Last Post: Mark604
Today 03:20 PM
Trailer Electrics - Fuses (2019 Van)
Last Post: Paperstone
Today 08:52 AM
Removing sticker residue
Today 08:29 AM
Identify a part
Last Post: mpj29201
Today 06:23 AM
ET18 and ET44 road wheels
Yesterday 07:50 PM
1.6 petrol Multispace battery isdue.
Yesterday 07:22 PM
Locked car while driving.
Last Post: Desdinova
Yesterday 06:19 PM
Intro / Model
Yesterday 06:17 PM
Hi
Last Post: Ringo2024
Yesterday 05:52 PM
