  • 7 Vote(s) - 2.86 Average
alternator 1.9 D 2004
hallo, to replace the alternator berlingo 1.9D 2004 is necessary to lower the engine?
Federico
sorry, confirm, not solved!
In a word no.
You'll need to remove the front offside wheel and the plastic splash cover to give access to the aux belt tensioner to slacken it (assuming you have the automatic tensioner).
The two bolts on the outer side are 16mm. A ratchet spanner will make it quicker to remove the top one. The inner bolts are female hexagonal, I used a hex bit with a 10mm spanner for the top one due to space limitations. The lower has plenty of room a ratchet wrench.
Replaced mine a week ago due to a noisy bearing. Got a replacement from a breakers for £30.
Good luck
thanks, but I managed to fix the problem without removing the alternator, had melted the voltage regulator of the alternator is just what I replaced.
solved
[-] The following 1 user says Thank You to federicocristiano for this post:
  • ron
Today 06:40 AM
Heater Matrix replacement
Today 06:20 AM
buying advice - bonnet release lever broken
Last Post: marzzden
Yesterday 10:36 PM
Heavy steering
Last Post: Romahomepete
Yesterday 06:06 PM
2023 electric
Last Post: Galagemm
Yesterday 12:08 PM
Oil sump design.
Last Post: Blakey
Yesterday 11:45 AM
Is this a problem coming?
Last Post: Robho
Yesterday 07:09 AM
Wind noise at speed
Last Post: Blakey
Yesterday 06:57 AM
Spare wheel
10-05-2024 09:28 PM
Part numbers with pictures (ServiceBox for free)
10-05-2024 08:45 PM
