  • 8 Vote(s) - 2.88 Average
Berlingo IBS and ECU Units
Thanks in advance - I bought the van, a 2003 1.9D (think it's a MK11 - large headlights) from my neighbour. He had bought it on line and was told it had a lighting fault. Problems start when starting from cold - engine fires up but sounds diesel knock for a few minutes. Then sounds sweet. Headlight flash works, sidelights work but no headlights when stalk is turned on. Then fuel gauge will fall to zero, handbrake warning light and charge light stop on. No rev counter, engine light comes and goes after about 10 mins when temp gauge goes up headlights start working.
Also wipers, rev counter work and charge light goes off. Drives ok for a bit then diesel knock comes back on and off with loss of power - like timing retarded.
I called auto electrician plug into scanner and he said it was showing permanent faults in ECU including cooling fan fault, EGR fault and other faults which he deleted.
He aslo said a wire from top of diesel pump my be a bypass wire for the immobiliser. Also there has been a press button fitted on dash I presume to bypass heater plug relay.
Now after auto elc. has gone I have a permanent diesel knock and loss of power, no temp gauge working which is now making van overheat as well as all other faults!!
I do like a challenge but it's obvious someone else has messed with this van and would be grateful for any advice. It is a shame cos van drives really nice when running ok!!
Thanks again for any info
Chaz
It could be some bad connections some where, If you could P/Mail me your Vin No. I'll have a look at the correct drawings.Icon_thumright
hi again. vin no from inner wing is. 0VF7GBWJYB94012211O.
Don't quote me but to me you have a few faults that might not be related to each other.
Do the basics, check main earths - engine and chassis. Check the battery is charged up and no loose connections.
As the engine will run then fault check the condition of the engine speed sensor (No.7 in diagram) and connections, this is essential for the injection.
Change fuel filter.
Also check these earth points
MC42 - for speedo unit
MC56 - for com2000 unit
MC13 & MC11 - for Bsi and engine fuse box module.
MC20 - head lights.
Do you have a multimeter?
.pdf   DW8B flywheel sensor.pdf (Size: 69.55 KB / Downloads: 34)
(07-04-2013, 09:43 AM)Rustscrat Wrote:  Don't quote me but to me you have a few faults that might not be related to each other.
Change fuel filter.
MC20 - head lights.
thanks, Will check on monday.dont have a m/m but will check earths first.
Hi again, thanks Rustcrat for diagram. Chased all earth points in large diagram, removed and cleaned themapart from EMO3L which I presume is wiper motor earth.
But small diagram in box E, I can't figure out where on the van that is! Any idea??
I have also found a second hand heater plug relay - thus trying to eliminate the extra wiring. But still showing no heater plugs light on dash.
Speed senser looks clean.
Once again thanks for your input
Chazy
It's the driver's side cab floor; look on the right and you'll see the door jamb - transmission tunnel is on your left.
[-] The following 2 users say Thank You to addo for this post:
  • chazy, Rustscrat
Ihave decided to risk buying a second hand bsi ecu and key,
cant find any wiring faults.Will post results.
[-] The following 1 user says Thank You to chazy for this post:
  • Rustscrat
(14-04-2013, 07:14 PM)chazy Wrote:  Ihave decided to risk buying a second hand bsi ecu and key,
Hi, I have a 2004 1.9d enterprise van model, with the exact same problem, bought a new comms 2000 unit and fitted with no change, still no lights etc, have also tried bsi  reset with no luck, may I ask did changing the bsi, Ecu and key solve your problem, many thanks Richard
Rick you are most unlikely to get a reply since chazy is no longer using the forum .... look at his details below ..
chazy's Forum Info
Last Visit: 18-05-2013, 08:54 PM
[-] The following 1 user says Thank You to geoff for this post:
  • ricksberlingo2020
Rear Suspension Rebuilders?
Today 08:02 PM
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Today 06:07 PM
Last Post: tdonbay
Today 05:44 PM
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Today 10:59 AM
Last Post: Wightlingo
Today 07:56 AM
Today 06:51 AM
