  • 10 Vote(s) - 2.6 Average
12v socket fuse
My 12v socket isn't working & I need to check the fuse. Has anyone found an easy way of accessing the fuse in the glove box ? Can the whole thing be hinged down into the footwell ?
Ha! getting it out is easy.
Getting it back in:
Superglue a cable-tie to the top of the new fuse.
Simples!
Even once you get the glove box door and frame off, its still squirreled away in an extremely awkward position - just about reachable with long fingers to remove. But getting back in is even trickier, as the available gap is only just wider than a fuse.
I eventually managed by gripping the fuse with the removal tool and maneouvering it into position held perpendicular between my middle and ring finger.
Expect to do a lot of swearing. What a F*****g stupid position to put one of the most likely fuses to blow.
The Bus II: 2019 XL Flair 1.2
(03-05-2013, 07:47 AM)Guanajuato Wrote:  Even once you get the glove box door and frame off, its still squirreled away in an extremely awkward position - just about reachable with long fingers to remove. But getting back in is even trickier, as the available gap is only just wider than a fuse.
Takes me 2 minutes to superglue.
3 seconds to put fuse in.
Have you got a photo of your adapted fuse setup ?
Tried again today, but fingers like sausages do not help
Rolleyes
Rear Suspension Rebuilders?
Today 08:02 PM
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Today 06:07 PM
Last Post: tdonbay
Today 05:44 PM
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Today 10:59 AM
Last Post: Wightlingo
Today 07:56 AM
Today 06:51 AM
