lightning strikes, Berlingo
So I was driving a chum of mine a while ago through a thunderstorm and he said a car is the safest place to be in a storm as the metal cage protects anyone inside.
ok, I sad, but the modutop roof on this one is plastic. He went a bit quiet.
I think it's called a Faraday cage?I would have thought the roof frame would be enough?
(20-01-2016, 07:33 PM)ron Wrote:  I think it's called a Faraday cage?I would have thought the roof frame would be enough?
Indeed
Is it not the tyre's that stop the lightening  going to earth and not using you and the car as a conductor and the smell of burnt skin get that out of your carpet's.  Sad
It's the same principal as an aeroplane. They get hit about once a year. The current flows around the outside as metal conducts best.
[Image: 300611gentesla7_170oh9n-170oh9p.jpg]
Out of all the french car's nemesis you had to struck on.......ELECTRICITY
You are lucky it didn't stop and die there and then. Mine just developed a backfire and loss of power for no reason. Knowing french it will be coilpack or spark plugs AGAIN! fak
[-] The following 1 user says Thank You to Kokain for this post:
  • ron
rubber tyres are black cos they put carbon in the mix, carbon is a god conductor of electricity ,  lightening will go straight through the tyres to ground,  wet tyres even better,    Smile
btw they put carbon in to stop uv light penetrating into the rubber and destroying it.
[-] The following 1 user says Thank You to ricc for this post:
  • ron
16 Plate Berlingo Multispace XTR
Last Post: Mr Bumblefluff
Today 02:46 PM
Last Post: marzzden
Today 09:37 AM
Yesterday 11:38 PM
Yesterday 08:54 PM
Rear Suspension Rebuilders?
Yesterday 03:37 PM
2023 electric
Yesterday 09:43 AM
Heater Matrix replacement
Last Post: Kieron G
Yesterday 06:20 AM
Heavy steering
11-05-2024 06:06 PM
Last Post: Blakey
11-05-2024 11:45 AM
Is this a problem coming?
Last Post: Robho
11-05-2024 07:09 AM
