  • 7 Vote(s) - 3.71 Average
First problem since october 2010
Having owned my Berlingo since last October, i might add without any problems until this afternoon.
So on our travels i had the noise of two beeps and the water temperture gauge needle was over the top, and at the bottom in red it sed stop.
Has anyone else had this happen, if so what is the problem, should i be worring has it happened twice.:whistle:
Had it on mine, it was the water temperature sender in the engine block.
It would come on, then go off after about 2 minutes, did this a few times, so I thought I'd replace it, took it out just for a nosey to see how hard it would be to replace ( very easy ) put it back in and it's been fine ever since!!
That was 2 years ago!
Has your radiator fan packed in?
Will have a look at that then, same engine as mine but mine is a 53 forte, thanks for the reply Steve..
Thanks Andre i will check that as well, but i think Steves hit the nail on the head as i had only just set off, and the water temp hadn't even got warm..
(02-04-2011, 08:13 PM)gary Wrote:  Will have a look at that then, same engine as mine but mine is a 53 forte, thanks for the reply Steve..
Yeh you're right, i didnt read it properly. Let us know how you get on
(02-04-2011, 08:13 PM)gary Wrote:  i had only just set off, and the water temp hadn't even got warm..
Same as what mine used to do, just took it out, looked at it, put it back, fixed!! like magic!! Big Grin
rear anti roll bar (torsion bar)
Today 07:46 PM
Heater Matrix replacement
Today 07:45 PM
Recommend accessories
Last Post: Galagemm
Today 07:20 PM
Last Post: Jakeblu
Today 02:39 PM
Last Post: Blakey
Today 02:30 PM
Today 11:29 AM
Trip + Clock Help
Today 11:25 AM
Speed Camera Warnings
Last Post: Desdinova
Today 09:49 AM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
