Question for camper converted Berlingos
Hi, when using the Berlingo for sleeping in how do members ensure adequate ventilation?
The obvious answer is to leave a window slightly ajar but depending where you are this could attract the attention of undesirables.
Is there any possibility of fitting vents in the rear inner plastic liners then through to the wheel arches somehow?
Just a thought, but this is something I would like to do myself.
Why would you need a vent? You can drive in it with 5 people all day long and it's fine... 7 people if you've the bigger one?
Sent from my iPad using Tapatalk
I kip in mine occasionally in the summer & haven't suffered any probs.
(15-07-2015, 08:01 PM)Tonyash Wrote:  Hi, when using the Berlingo for sleeping in how do members ensure adequate ventilation?
I think that in the past you said you had window deflectors fitted? Could you not just crack the front window open 1/2 inch that should give reasonable security.
Failing that something like :-
http://www.ebay.co.uk/itm/UNIVERSAL-CAR-...1713916234
but I think they would leave the window open quite wide.
I wouldn't of thought that vents through the wheel arches would be a very good idea for either camping or driving.
When camping surely your mattress etc or camping box (amdro type for eg) would block them and when driving you'd get extra wind noise and rain going into the external part of the vent.
I wouldn't worry about ventilation, I've never heard of anyone who uses their car as a camper mention such a problem.
[-] The following 1 user says Thank You to Jelster for this post:
  • Lukemedia
Where on the car gets most road grit, salt and water thrown at it ? Don't sleep in places where undesirables might frequent and just leave the ventilation set to the cabin so air will circulate naturally, the car is far from airtight.
  • ron
Unfortunately these sort of window grills don't work on the berl window because the front windows have the verticle gap.....
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
