Threads: 16
Thanks Given: 3
When I just started up I got the above warning. I have a 2003 2.0 HDi
Can anyone shed some light on this please?
Cheers
Marco
Threads: 6
Thanks Received: 9 in 7 posts
Thanks Given: 1
No oil pressure/ Low oil level. Have you recently changed the oil? Or parked on a steep hill (The sensor is either on the front or the back of the sump I believe, oil can drain away and give a false reading.) Is the big STOP light showing? It could be oil level, pump, or faulty sensor. Check the oil with the dipstick first.
Threads: 16
Thanks Given: 3
Thanks for that. I checked the dipstick and it barely registered any oil (it was very dark though) I put in about 1/2 litre and the readout changed to ooooooF which I think means it's at max. I didn't want to put in very much as I had in the back of my mind that too much oil is worse than not enough
I only had it MOT'd and serviced about 5 months ago. I can have a better look tomorrow when it's light. Thanks
Threads: 5
Thanks Received: 2 in 1 posts
Thanks Given: 5
My 2003 2.0 HDi does this every time I start it up in the morning. We have quite a severe camber on our street, and it either does _ _ _ _ _ _ _ or ooooooo, depending which side of the road I park on!
I just ignore the warning and check it weekly on the dipstick, the old school way...
2003 Partner 2.0 HDi Escapade
Threads: 20
Thanks Received: 13 in 13 posts
Mine goes through phases of giving dodgy readings, new sensor is on to do list. Never rely on sensors when it comes to oil level, always check your dipstick once a week.
Hi I have a similar problem with my Berlingo its a 2003 Hdi I have only owned it for about 6 weeks sometimes I get the __________f other times oooooof on a short journey recently I heard a beep a and the engine management light came on. I checked the oil level which was fine, the light went off after a couple of days. But i still get the alternative readings on the gauge, tonight the light came on again after several weeks without it. Once recently on the motorway I seemed to hit a flat spot and the car wouldn't pick up for a while then later on it seemed to run fine again. Can anybody please help.
Regards
Jason
Threads: 23
Thanks Given: 50
29
The flat spot your talking about is called limp mode could be faulty sensor or the EGR not opening closing properly do you know any one with a fault code reader ??
Thanks Given: 188
23
The different readings for the oil level could be the sensor in the block could be faulty, they are easy to replace but don't rely on it and check the level manually once a week. Then you will get used to how much if any the motor uses.
As jed advised it really needs connecting to a diagnostic machine to see if there is any faults logged.
Are we there yet?????
