  • 1 Vote(s) - 3 Average
Berlingo Amelie a working Van
    Hello all I am going to post about my present Berlingo van 'Amelie' Heart  She is a working van and so not very glam-looking but she does have to earn her living. (Like her owner..) Cry
Opps..! Did I say that..! Tongue
[-] The following 1 user says Thank You to Bill Rose for this post:
  • whitebus
We love the film "Amelie" and Audrey Tautou of course. Post some pictures (of Audrey, not the van I see enough of them) Big Grin
[-] The following 2 users say Thank You to ffrenchie for this post:
  • Bill Rose, whitebus
(13-04-2015, 08:55 AM)ffrenchie Wrote:  We love the film "Amelie" and Audrey Tautou of course. Post some pictures (of Audrey, not the van I see enough of them) Big Grin
The Lady in question... Oh. La La..!
Attached Files Thumbnail(s)
  • whitebus
        Smile A few photos of my little 'Amelie'
I have cut off a lot of the plastic trim on the van. The back doors plastic got cut so I could easily replace the light bulbs on the number plate and get at the lock to grease it up.
I have also cut the main door trim, to get at the window winder & locks .Also the plastic trim on the bottom of the doors gets in the way when getting in and out..
I use the internal metal panel to hold bits and bobs... Rags sweeties, phone, small tools etc.
It also helps reduce some of the weight of the van too.
  • whitebus
eeeeeeee !!! along comes what might have been a great sexy titties thread an someone comes along and posts a pic of some doors!!!
booo bill rose booo !!!!
ok.ok its a partner  Tongue
[-] The following 1 user says Thank You to whitebus for this post:
  • Bill Rose
(20-04-2015, 03:45 PM)whitebus Wrote:  eeeeeeee !!! along comes what might have been a great sexy titties thread an someone comes along and posts a pic of some doors!!!
Well there will be more photos of the French Lady, for fun...
  • whitebus
Roof Bars / Rack
Amelie, A Working Berlingo Van.
Things & Bits that I have Modified on my Berlingo Van.
The roof-bars. I have added two thick planks of wood between the two standard Citroen roof-bars. I used 4 'U' bolts to clamp the wooden planks to both bars. (See the photos..) The wooden planks are 100-mm wide by 25-mm thick and around the length of the vans roof line.
The 'U' bolts are tightened and the nut-heads are counter-sunk into the wooden plank. The threaded stubs are cut off. Leaving a flat, clear working surface on the top of the roof line.
This makes the roof-bars much stronger for carrying ladders, timbers and roof-boxs etc. The weight is carried / shared between / across  the roof-bars more evenly. It also means if one of the clamps works loose over time (With bumps & potholes) Then the other clamps help hold your load on and stop it from falling off..!
With this method you can also add /remove the whole roof-bar /roof-rack all in one go. And it fits inside the van if you need to keep it secure from thieving trolls.
I took the end caps off the Roof bars to make it easier to grease the bolts.
Then of course the lovely Audrey Tautou / Amelie..!
  • whitebus
Is this a porno site or just thing's you can or had in the back of your berlingo  Wink
[-] The following 2 users say Thank You to Jed Clampit for this post:
hahahhahahahha !!! nice work peeps Smile
im off to the err ? ... .... toilet,yes toilet!! for no suspicious reason ...
  • Bill Rose
You all realise I only post the photos of the French Lady, just so you will read the things about the van, don't you... Rolleyes
Any way no naughty photos. just 'Artistic' poses... Its the French Way. Oh-La-La..!!!
  • whitebus
Today 08:54 PM
Rear Suspension Rebuilders?
Today 03:37 PM
Today 12:15 PM
Last Post: uk_friendly_fire
Today 11:50 AM
2023 electric
Today 09:43 AM
Heater Matrix replacement
Last Post: Kieron G
Today 06:20 AM
Heavy steering
Yesterday 06:06 PM
Last Post: Blakey
Yesterday 11:45 AM
Is this a problem coming?
Last Post: Robho
Yesterday 07:09 AM
Last Post: Blakey
Yesterday 06:57 AM
