Threads: 52
Thanks Received: 82 in 76 posts
Thanks Given: 145
7
My doors feel as if there is grit in the runners, what do people recommend for cleaning the tracks and keeping the doors running smoothly please?
Matt
2019 Multispace BlueHDi 100 Flair Nimbus Grey Met
Threads: 42
Thanks Received: 87 in 60 posts
Thanks Given: 34
10
16-11-2023, 12:03 PM
(This post was last modified: 16-11-2023, 12:13 PM by Multispacer.)
(16-11-2023, 11:42 AM)Matt Haigh Wrote: My doors feel as if there is grit in the runners, what do people recommend for cleaning the tracks and keeping the doors running smoothly please?
After giving the tracks a good clean I normally use silicone grease in spray form. I've found that any thicker type [like vaseline or silicone grease paste type] accumulates too much grit and probably does more harm than good.
The cheapest place to get spray cans of Silicone Grease that I've seen is when they have them in stock [they tend to be in the offers with either car stuff or DIY stuff] in the German discount supermarkets [Lidl/Aldi] normally around £2.99 a can.
_______________
2008 B9 1.6Hdi Multispace XTR
2007 M59 1.6Hdi Multspace Desire
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Threads: 75
Thanks Received: 1,282 in 1,134 posts
Thanks Given: 223
162
Cans of compressed air for computer air-dusting would work to blast the grit out first, then lube as advised above by @
Multispacer. You can get those online easily.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
The following 1 user says Thank You to Sol for this post:1 user says Thank You to Sol for this post
• Matt Haigh
Thanks Given: 192
45
My sliding doors get in a heck of a state mostly down to my dogs being on and off the beach - they jump in and out and the sand gets in everywhere.
The doors are hard to get moving / close from the fully open position and rumble like the devil as they slide both ways.
I use a garden hose with the trigger gun set to " jet " to direct water into and along both top and bottom rails ( dooors open whilst doing so ! ) and work the doors open and shut whilst washing the gubbings out
This does the trick for me
Once washed out it is best to lube everything if you can
I buy WD40 liquid by the gallon ( I have lots of other uses / hobbies ) and using a hand squirter much like a kitchen cleaner bottle give the gubins a good sluicing with the stuff, does the job.
Otherwise use an aerosol oil spray or a spray grease - as said Lidl etc often have decent stuff at agreeable prices
• Matt Haigh
