Threads: 67
Thanks Given: 1,045
22-03-2013, 01:07 PM
(This post was last modified: 22-03-2013, 01:22 PM by addo.)
Just briefly, edit out your VIN - it can be used to cut keys and obtain the ECU unlocking code.
It's a Lucas pump, there's not a lot of detail beyond that in the diagrams. Citroën themselves don't do internal parts but I would suspect the shaft seals and bushes are easy enough to get from third parties; maybe try "dieselbob".
The following 1 user says Thank You to addo for this post:1 user says Thank You to addo for this post
• leeandoona
Thanks Received: 2 in 1 posts
Thanks Given: 5
23-03-2013, 04:39 PM
(This post was last modified: 23-03-2013, 04:48 PM by leeandoona.)
Everyone, thank you all so very much. This would have been the end of my much loved Berlingo had you all not had helped. I checked in the Haynes guide and discovered it appears to be a Lucas pump and reasonably early. The pics from Rustscrat above confirm this also which was hugely helpful plus of Course Ron for advising the seal/o-ring could be replaced and for giving me some direction on where to get the part. Until these updates, I was left looking at either getting a new pump (silly money at garage), a breaker's yard found me one for £40 but of course no guarantees and a local Garage had offered to look it over F.O.C with a view to seeing if it was the "4 bolt" pump that could have it's lid taken off (like the pics from Rustscrat shows). I'm hopeful that I can track down the repair kit I need now and fix this myself. I will of course update everyone on how I get on.
Just a quick update. eBay does have it's uses...looks like i can solve this for some time with my spanners and £12!!!! (
http://www.ebay.co.uk/itm/LUCAS-CAV-DPC-...257bfd6bb9)
Looks like the right thing. Still seems a lot for two bits of rubber but a lot better than the £350 I was quoted by the garage..thieving so and so's. (and they wonder why people don't trust garages!!!).
If it ain't broke...don't!:thumbsup:
Thanks Given: 192
45
Regarding the seals at least they are supplying Viton which is the correct material for the job.
Thanks Given: 5
:censored::brickwall::censored::brickwall:
AARRGGHHHH!!!! Okay, I blew it. I replaced the seals, easy peasy lemon squeezy even for a fool like measy. Then...On re-assembly, the bolt on top of the throttle spline (which the seals go onto) just sheared off. I wasn't even turning it that hard. So now I need a new Spindle I suppose.
Can anyone tell me if these are easy to replace before I try and hunt one down from somewhere?
Also, I tried to bodge it by drilling a pilot hole into the snapped off neck of the spindle with a view to screwing in a self tapping screw to hold the washer in place. This worked but on starting the van, it was revving at full trottle...quickly turned it off of course. I assume this is because the bolt that sheered off is integral to turning the spindle to control the throttle and I guess it's stuck in the full throttle position so I can't move it anywhere until I've replaced it now. Good and proper :censored:
