Threads: 20
Thanks Received: 12 in 10 posts
Thanks Given: 1
How do i remove the drivers door panel on a Mk 3. I have removed the three self tappers but cannot see what else i have to do to get it off. There is something loose in the door that is annoying the pants off me.
Thanks Received: 26 in 24 posts
Thanks Given: 52
I have a door rattle on my 63 plate, I just turn up Ken Bruce....
63 plate Berlingo working hard.....
Threads: 24
Thanks Received: 6 in 5 posts
Thanks Given: 8
Same problem with mine- 60 reg, doing my head in!
Thanks Received: 213 in 171 posts
Thanks Given: 44
5
When I had a rattle inside my drivers door it was window regulator come loose. That was fixed under warranty luckily. Can't help with panel removal sorry but Cit garage fixed it while I waited so there must be some trick that gets it off quick. ATL you could get that fixed under warranty, probably a good idea if it is loose regulator.
Threads: 20
Thanks Given: 1
Mines a 58 plate so no warranty. Surely it cannot be that hard? Anyone???
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
you need to pull it off the clips, start at the bottom, screw driver with a bit of cloth so you don't scratch the paint and gently lever it off
Threads: 23
Thanks Received: 498 in 455 posts
Thanks Given: 48
27
As finny wrote start from the bottom you also have to take the door handle cove off with a leaver on the inside of that there are torx screw's  the inner door mirror cover also need's to be leaverd  off  put some thing behind the leaver so not to damage the door card when you've pull all the panel clip's out you will need to lifted the door card upward to to release the top of the door card
Threads: 20
Thanks Given: 1
Brilliant, thanks so much for all the replies. Just ordered the tools.
