headlights for europe
Does anyone know if the headlights can be adjusted for driving in Europe? if not then i guess stickers are the only way.
That topic has been covered a couple of times if memory serves but the solution escapes me at the moment. A search should turn up helpful information.
I frequently drive on the Continent, and I gave up years ago bothering about adjusting the headlights to dip to the right rather than left or even putting stickers on them. Simply adjusting them as low as they will go is quite sufficient. If you really want to do more, use black insulation tape to block out the section of the headlight glass through which light shines to the left and upwards. But, in my experience, you really don't need to bother.
I set my H/lamps low & never get flashed on A roads which leads me to believe they're acceptable.
(29-03-2015, 04:03 PM)doofer Wrote:  I know the odd occasion I've seen someone parked on the left facing me with their headlights on, it's blooming dazzling and this is what the oncoming traffic would have to put up with if you were driving on the other side of the road. I doubt that tipping them down would be enough, and you'd be at risk of getting stopped as well as annoying lots of people.
Well exactly. It doesn't take a genius to work out why those over the channel think we're a load of arseholes does it?
What berlingo do you have if it's a MK 3 i don't think you need to do anything the way the light's are set up these day's they have a level cut off point so you don't get the scatter of the older type of light's
(29-03-2015, 06:16 PM)ron Wrote:  I set my H/lamps low & never get flashed on A roads which leads me to believe they're acceptable.
Me, too! The adjustment on the Berlingo allows you to set the dipped headlights very low. Just got back from France again and had no problems.
http://shop.theaa.com/store/home/aa-head...converters
Many retailers sell them, for a few quid its not worth the hastle of being stopped or being inconsiderate to others.
You don't need to stick beam changers on current Berlingo. I emailed Citroen & they sent me a letter stating they are not required.
[Image: scan0011.jpg]
Thank you Opensauce i was sure i read it some where  Smile
Trip + Clock Help
Yesterday 10:01 PM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
Windscreen wipers banging
Yesterday 09:48 PM
2012 1.6hdi Won't start!
Yesterday 09:43 PM
Yesterday 08:19 PM
Speed Camera Warnings
Last Post: StarFish
Yesterday 03:20 PM
Teletrac sat nav tracker
Last Post: ItsGreen
Yesterday 01:45 PM
New owner of a K9 2019
Last Post: Ringo2024
Yesterday 10:44 AM
Wind noise at speed
Last Post: StarFish
Yesterday 06:33 AM
