new air cleaner?
Threads: 7
Thanks Received: 3 in 3 posts
Thanks Given: 4
[attachment=2232][attachment=2233]Had the car for 3 weeks and have done 850 miles of mixed driving.
The non-franchised dealer serviced the car before I took delivery.
The service schedule hadn't been stamped so that was done before leaving the dealeship but the service due indicator had been reset.
Question is - does this air cleaner look like it's only done 850 miles? New to diesel ownership so comments appreciated!
Threads: 23
Thanks Given: 46
5
Unless you have been driving through bonfires etc. I would have thought that had done much more than 850 miles.
Threads: 20
Thanks Given: 2,126
18
I agree with Trevor.The pollen filter?looks awful.
Strawberry flavoured windows
Threads: 23
Thanks Received: 498 in 455 posts
Thanks Given: 48
27
I would also say it has not been changed
Threads: 7
Thanks Given: 4
Thanks for the replies guys - you've confirmed my suspicions and no, not been driving through bonfires
Tomorrow the oil and filter will be changed - as a precaution.
I suspect the pollen filter will be equally bad, is it located in the same place as the M59 model i.e. under the dash on the passenger side?
Threads: 19
Thanks Received: 51 in 49 posts
Thanks Given: 17
4
(25-04-2015, 05:25 PM)JT1 Wrote: Had the car for 3 weeks and have done 850 miles of mixed driving.
85,000 miles more like...
Threads: 23
Thanks Given: 46
5
(25-04-2015, 09:26 PM)JT1 Wrote: Thanks for the replies guys - you've confirmed my suspicions and no, not been driving through bonfires
I believe that your being very wise I would think all your service consisted of was re setting the service indicator.
I assume that you have a Mk3 ? the pollen filters are by the drivers knees on the Mk3
You say that you are changed the oil? did you check which oil to use? as this is very important.
Threads: 35
Thanks Received: 118 in 87 posts
Thanks Given: 3
4
26-04-2015, 07:30 PM
(This post was last modified: 26-04-2015, 07:55 PM by ntm1275.)
I think the air filter service interval is 25000 miles, so unless you are at either at 25000, 50000 or 75000 etc, etc, it won't have been done
i.e if you are at 31000 miles for example, the dealer will assume it was already changed at 25000 and doesn't need to be changed for another 19000 miles
The same would apply to any other service part
Fuel filter at 50000
Cam Belt at 100000
Would you expect both cambelt and fuel filter to be changed at 31000 miles, the only thing they probably would change would be the oil and oil filter
Threads: 7
Thanks Given: 4
(26-04-2015, 07:01 PM)Trevor Wrote: (25-04-2015, 09:26 PM)JT1 Wrote: Thanks for the replies guys - you've confirmed my suspicions and no, not been driving through bonfires
Thanks Trevor,
I used a fully synthetic 5/30 oil which meets the B71 2290 PSA standards, supplied by my local motor factors. The car is likely to do only about 7k a year but I intend to change the oil annually just in case. The filter was a faff, couldn't get it out of the housing until I read on here 'just twist and pull' which with a bit of persuasion, worked. Had to convert Nm to lbs/ft as my torque wrench is so old it doen't have Nm, it's 18.4 lbs/ft if anyone is interested and my wrench starts at 20...
It is a Mk3 so thanks for the location of the pollen filters, otherwise I'd have spent a few hours looking in the wrong footwell!
Jeremy
Threads: 7
Thanks Given: 4
(26-04-2015, 07:30 PM)ntm1275 Wrote: I think the air filter service interval is 25000 miles, so unless you are at either at 25000, 50000 or 75000 etc, etc, it won't have been done
Cam Belt at 100000
Fair comment. Looking at the Maintenance and Warranty Guide which came with the car, it shows the air filter as needing to be replaced at 37,500 miles which seems excessive (a C1 petrol is listed at 40,000!).
The car has done only 20,000 miles and I don't think it's seen too many arduous conditions as it spent the first part of its life in south Cumbria, Yet the air cleaner looked pretty filthy so more than likely wasn't replaced at the last service. It may be the original - I'll check who manufactured it.
buying advice - bonnet release lever broken
Today 12:15 PM
OBD Faults listed - which how to fix?
Last Post: uk_friendly_fire
Today 11:50 AM
Do thing right themselves?
Last Post: Anyinfo
Today 10:35 AM
2023 electric
Last Post: Anyinfo
Today 09:43 AM
Last Post: Romahomepete
Today 07:21 AM
Heater Matrix replacement
Today 06:20 AM
Heavy steering
Yesterday 06:06 PM
Oil sump design.
Last Post: Blakey
Yesterday 11:45 AM
Is this a problem coming?
Last Post: Robho
Yesterday 07:09 AM
Wind noise at speed
Last Post: Blakey
Yesterday 06:57 AM
