[Engine] Will peugeot 206 1.4 fuel pump work in berlingo 1.4
Hi. I'm facing a problem with my berlingo's fuel pump. I managed to get a Peugeot 206 fuel pump. Since both cars are usin the same engine, can the fuel pump for peugeot be fitted and works in my berlingo? Can anyone provide me with an answer? Much obliged. Thank you.
Yes buddy it will be fine. It's a 1525 h8 fuel pump
[-] The following 1 user says Thank You to Kokain for this post:
  • Akhish
Thank you and much obliged Kokain...
A parts dealer in Malaysia said that the pump is totally different between 206 and berlingo. I believed it should be ok but even my mechanic is in doubt because he had an experience with a citroen evasion. Is there any difference between 206 fuel pump and berlingo fuel pump?
http://cgi.ebay.co.uk/320926927358
  • Akhish
(28-05-2015, 12:47 PM)Kokain Wrote:  http://cgi.ebay.co.uk/320926927358
Thank you bro... you've been a lot of help... now I know what I must do.... thanks again...
thank you very much appriciate the comment.
mercedes service
Hi... Did the repair last Monday... The mechanic took out the old fuel pump and change the pump  only. Now the car is moving again. Used a pump from a peugeot 206 and the job was completed within 2 hours. Still having a trial run with the car and so far have travelled 200 km. Had a glitch earlier in the day when the car lost power and the engine warning light came on. Left the car for a couple of hours and the problem just went away. Hoping that it won't return. Had the same problem a few years back and had to change the throttle body. That was 6 years ago. Any kind of suggestion to what problems that I should look out for is highly appreciated. Thank you...
Heavy steering
Last Post: Romahomepete
Today 06:06 PM
2023 electric
Last Post: Galagemm
Today 12:08 PM
Oil sump design.
Last Post: Blakey
Today 11:45 AM
Is this a problem coming?
Last Post: Robho
Today 07:09 AM
Wind noise at speed
Last Post: Blakey
Today 06:57 AM
Spare wheel
Yesterday 09:28 PM
Part numbers with pictures (ServiceBox for free)
Yesterday 08:45 PM
ET18 and ET44 road wheels
Last Post: pondweed
Yesterday 03:29 PM
Can you clamp the rubber brake hose?
09-05-2024 09:07 PM
Upgrade audio system
09-05-2024 09:04 PM
