No brake lights Berlingo b9 59 plate
Coming home last night I was flagged to say I've no brake lights.
Checked and changed bulbs, checked fuses but still nothing.
Next thought is brake switch but can't find it.
Or could it be anything else?
Any advice would be great.
Hi, on my earlier Berlingo the brake light switch was mounted on the pedal under the dashboard, it was a sprung loaded plunger switch that is released when the pedal is depressed, on a couple of occasions it slipped it's mount resulted brake lights on .
You may have a similar set up on the b9 , it's worth a look but a pig to get at !
Good luck
Mark
I've looked but can't find it.
Unless it's further behind the dash??
I've just had a look on eurocarparts and the switch listed for my current b9 is a plunger switch, so I'd say it's down there !
To access it on my earlier Berlingo I had to lie upside down with a torch in my mouth to get at it and see what I was doing !
Mark
I'll try again then. Cheers mate.
Let us know how you get on.
Good luck.
Mark
So now I've checked all fuses in engine bay, checked and changed bulbs, found and changed brake switch but still no lights.
I'm now a bit lost
Have you checked the fuse box under driver side just below steering wheel
No as I didn't know there was 1. Will go check in a moment
Didn't find fuse box by steering wheel. But checked those in glovebox and there all fine.
Hi
Last Post: Jakeblu
Today 02:39 PM
Wind noise at speed
Last Post: Blakey
Today 02:30 PM
2012 1.6hdi Won't start!
Today 11:29 AM
Trip + Clock Help
Today 11:25 AM
Speed Camera Warnings
Last Post: Desdinova
Today 09:49 AM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
Windscreen wipers banging
Yesterday 09:48 PM
Yesterday 08:19 PM
Teletrac sat nav tracker
Last Post: ItsGreen
Yesterday 01:45 PM
