  • 5 Vote(s) - 2.8 Average
Strange sound from rear berlingo multispace 2002
Hello. first of all. I'm from Norway so my english can be a little strange some times.
I have a 2002 berlingo that lately have had some strange sounds from rear end.
it started with a cracking sound when i was driving in bumps.
No it's more like squecking sounds and knocks.
I can't see anything wrong but have read the forum and found different answers like torsion bar and the brake regulator.
If the torsion bar is damaged, how will I notice it?
I'm hoping for the brake regulator...
the brake regulator is usually a TWANG sound from the spring,when you release the handbrake or go over bumps
Hi, It could be your rear axle swinging arms if you are unlucky! :S
If it was a torsion bar you would notice the difference in height when looking at the back.
(03-08-2012, 12:22 PM)Rustscrat Wrote:  Hi, It could be your rear axle swinging arms if you are unlucky! :S
You mean a difference between left and right rear wheel?
I have the same issue with a "loud" rear axle, but my car have an extreme camber on both sides so I assume my only solution is to replace the rear axle.
Hi, get someone to bounce on the back of the van while you listen underneath. If it's the "cracking" sound then it's more than likely the axle has gone. Confusedillyme:
(21-10-2012, 09:05 AM)Rustscrat Wrote:  Hi, get someone to bounce on the back of the van while you listen underneath. If it's the "cracking" sound then it's more than likely the axle has gone. Confusedillyme:
Am I right in thinking Morris 1000 front suspension used to collapse if a torsion bar broke
sorry off topic
Hi
Last Post: Jakeblu
Today 02:39 PM
Wind noise at speed
Last Post: Blakey
Today 02:30 PM
2012 1.6hdi Won't start!
Today 11:29 AM
Trip + Clock Help
Today 11:25 AM
Speed Camera Warnings
Last Post: Desdinova
Today 09:49 AM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
Windscreen wipers banging
Yesterday 09:48 PM
Yesterday 08:19 PM
Teletrac sat nav tracker
Last Post: ItsGreen
Yesterday 01:45 PM
