Seatbelt Differences
Hi All,
I have a 2014 LHD EU spec Multispace & I need to replace my seatbelts as the pretensioners have been fired, the part number of my Driver's side (LHS) one is 98025582XX, for some reason these are much more expensive on eBay than 98025583XX, everything seems to be the same with the exception of the pre-tensioner part, does anyone know what the difference is or does anyone have access to Citroen's system to see if these are just a supersession, please?
Can't help you there, but there are companies that will repair your seatbelt unit, eg, https://airbagteam.com/product/category-...lt-repair/
They do list a specific repair for the NS belt, https://www.ebay.co.uk/itm/225768259492
Probably cheaper than a scrapyard one from what I can see.
Try this
https://www.catcar.info/citroen/?lang=en&l=
 Select your model and see what comes up for seat belt part numbers
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white  Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(24-10-2023, 10:59 AM)shtu Wrote:  Can't help you there, but there are companies that will repair your seatbelt unit, eg, https://airbagteam.com/product/category-...lt-repair/
Thanks, but my driver's side belt (LHS) is a bit tired, so I want to replace it with a passenger side belt from a RHD car, so that it's had less use.  I'll bear this in mind for the passenger side though.
(24-10-2023, 11:28 AM)brodfather11 Wrote:  Try this
Thanks for the link, but most of the options have part numbers in a different format, the only one that's showing in the same format is the 98025582XX, the 98025583XX number is not featured anywhere.
Incidentally, do you know what the "until/since OPR------" relate to, is it chassis number or something else, thanks?
The OPR number is code for the build date . It is found on the sticker ( R/hand Drive model ) on the drivers door frame. Presuming yours is a left hand drive then it will be on the drivers door frame (r/h side ) ( I think)
[-] The following 1 user says Thank You to brodfather11 for this post:
  • Limbs
98025583XX if for left seat on right hand drive car with no passenger airbag.
No airbag means no left front airbag, as passenger sits on left on RHD cars  Exclamation
This attached view can be found at catcar in commercial vehicles section -> van. Link to catcar
Attached Files Thumbnail(s)
Last Post: saskak
Yesterday 07:30 PM
Last Post: rnamman
Yesterday 03:01 PM
12-05-2024 11:38 PM
12-05-2024 08:54 PM
Rear Suspension Rebuilders?
12-05-2024 03:37 PM
2023 electric
12-05-2024 09:43 AM
Heater Matrix replacement
Last Post: Kieron G
12-05-2024 06:20 AM
Heavy steering
11-05-2024 06:06 PM
Last Post: Blakey
11-05-2024 11:45 AM
Is this a problem coming?
Last Post: Robho
11-05-2024 07:09 AM
