  • 14 Vote(s) - 3.21 Average
[Transmission] Growling transmission ?
Growling noise,particularly on smooth roads. which continues when engine de clutched or coasting .Both wheel bearings changed and new drive shafts fitted.
Is this a gearbox problem ...like the differential ?Noise seems to decrease on left hand bends hence wheel bearing change. 150000 miles on the clock and gearbox seems fine.
(24-02-2012, 12:14 PM)Wobbly Wrote:  Growling noise,particularly on smooth roads. which continues when engine de clutched or coasting .Both wheel bearings changed and new drive shafts fitted.
Got the same problem with a Mk1 2.0 Hdi Berlingo. It seems to weep gearbox oil from the driveshaft seals, so I am going to replace them & then drain & re-fill gearbox.
Did you replace both wheel bearings? both my M49 had wheel bearing trouble around the 89000 mark and on both the failing bearing was the one on side that was unloaded in the bend IE nearside on a L/H bend.
Also on my 2.0hdi I replaced both bearings with items from euro car parts and a year later they started to make the same noise I replsced them with unipart items (SKF bearings) touch wood every thing is fine, when the old bearings where removed (euro car parts) it looked like the hardening treatment on the inner races was pitting. I have had the bottom pulley problems (damper rubber breaking up) and I thought I had a bearing going when it first started (the sound appeared to alter on bends as well) but it develops quickly into a sound like a black cab then very expensive/terminal sounds, but a replacement was about £50.00
mine used to make that noise and it was the box buggered
Locked car while driving.
Last Post: Hughzie
Yesterday 11:45 PM
Last Post: ThomasTheTMC
Yesterday 08:31 PM
Very brief warning light
Last Post: Mark604
Yesterday 03:20 PM
Last Post: Paperstone
Yesterday 08:52 AM
Yesterday 08:29 AM
Identify a part
Last Post: mpj29201
Yesterday 06:23 AM
ET18 and ET44 road wheels
18-05-2024 07:50 PM
18-05-2024 07:22 PM
Intro / Model
18-05-2024 06:17 PM
18-05-2024 05:52 PM
