  • 6 Vote(s) - 3.83 Average
towbar fitting
#11
(20-09-2014, 03:34 PM)Hardnut Wrote:  I get the maxi fuse, but what the lexia/diagbox got to do with tow bar ?
If using the genuine Citroen connectors already in the car, this needs to be activated for the wiring to work
To activate it you need a Lexia/Diagbox
If you are using non-genuine towbar wiring that does not use the connectors already in the car, then you don't need it activated
There is no plugs in my van. Can I just do it the old fashioned way and just wire it into back lights? I know I couldn't do it on my vectra because of the cambus, wasn't sure it Citroën was the same. This is my first none vauxhall van. The towbar sends the reverse sensors nuts as well, or well can't have everything
(21-09-2014, 08:17 PM)kesty Wrote:  There is no plugs in my van. Can I just do it the old fashioned way and just wire it into back lights? I know I couldn't do it on my vectra because of the cambus, wasn't sure it Citroën was the same. This is my first none vauxhall van. The towbar sends the reverse sensors nuts as well, or well can't have everything
hi you don't need the pugs just buy 7pin relay zr2500 from ebay ten just wire into side lights brake lights and indicators you need the relay to protect your electricts in van simple job
Thank you digger963, thats what I need! A simple solution cheers
Speed Camera Warnings
Last Post: StarFish
Today 06:37 AM
Last Post: StarFish
Today 06:33 AM
Trip + Clock Help
Last Post: Kelvasco
Yesterday 09:48 PM
Last Post: xtimex
Yesterday 08:57 PM
P1338 Fault code.
Last Post: ilikesprouts
Yesterday 07:36 PM
» Replies: 20
Seat cover zip
Yesterday 07:32 PM
More battery
Yesterday 06:05 PM
Steering Wheel
Last Post: limey2000
Yesterday 04:30 PM
Last Post: uhurusurfa
Yesterday 03:21 PM
FREE B9 rear parcel shelf
Last Post: Sparky58
Yesterday 01:27 PM
