25-03-2016, 04:58 PM
Hello all
I have just bought a 59 plate Berlingo 75k on clock and whilst driving it home I noticed that when I put it in 5th gear and accelerate gently the gear stick moves significantly and deceleration causes it move back the other way. If you hold the gear stick you can feel a knocking through the gearstick? There is also quite a lot of play in the stick from left to right but only when in 5th. The gear changes are slick there doesn't appear to be any problem with the gearbox so I was wondering if it's to do with any kind of linkage or the beginning of something more serious thanks in anticipation
is this easy to check or will it require a mechanic to look
