Gearbox blew up on the van yesterday, barely made it home with one gear left and the worst noises coming from it i have ever heard from a car!
I need to know which gearboxes are compatible with my berlingo, its a 2006 1.6HDI.
How can i know which gearbox i am buying it the correct type, loads on ebay just need some info on them for the 1.6.
Hope you can help
Craig
Threads: 67
Thanks Given: 1,045
Can work it out from the last eight digits of your VIN.
The vin is 93409178, what gearbox do I need?
Threads: 67
Thanks Given: 1,045
The gearbox will have etched on the ID pad (normally on the front side) DP37, or DP3G. You need a replacement box with either of these codes on it, or DPC7.
Matching these codes will guarantee the correct ratios as original.
I am struggling to find any boxes with those codes local to me, am I right in saying then that all the berlingo boxes will fit that generation of car just the ratios will be different?
Threads: 67
Thanks Given: 1,045
09-06-2014, 09:37 AM
(This post was last modified: 09-06-2014, 09:38 AM by addo.)
If it gets desperate, yes, just make sure the clutch fitment is the same style/position and it's from a 1.6 diesel.
To be honest, I don't know how many of the pikey type breakers even know where to look for the code.
Threads: 67
Thanks Given: 1,045
Keep scouting around, don't overlook Gumtree or the people breaking a similar age 1.6HDi van.
Ok brill, well the next thing is to get my gearbox off. Taken gearboxes off a few cars over the years but do you have any pointers on removal? Any guides anywhere?
Threads: 67
Thanks Given: 1,045
There's nothing sneaky about them, you should replace the driveshaft oil seals when installing and consider a new release bearing for the clutch.
