  • 10 Vote(s) - 2.9 Average
fan running after engine turned off
bought a 2006 1.6i a week ago. last 2 days the fan has come on after I turned the engine off. had a y reg 1.6i berlingo for 6 years before that and did not have this happen. fan stopped after a few minutes. can still take it back to the garage for tweaking if its a problem. is it normal for this model? anyone else experienced it (recently maybe?)
thanks
I am pretty sure mine has continued running after switch off if it was already running.
I can't recall is coming on after switch off to my knowledge.
[-] The following 1 user says Thank You to tucker for this post:
  • wandering
Thanks for your reply, Tucker. I am a little concerned about it, only seen it on an old old VW camper before this.
Bearing in mind the temperatures we've been having I'm not surprised. When you turn the engine off, due to the lack of coolant pump operation and air flow through the rad you will get an increase in coolant temperature. This causes the fan to switch on, common on a lot of cars! I havent specifically looked at your model of bingo so don't know if the same applies but I wouldnt be overly concerned unless it does it in cooler temperatures. Is the temp gauge normally static? if so after turning the engine off wait in the vehicle until the fan cuts in and turn the ignition to position 2 but dont start. Watch the temp gauge and see what if anything happens.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
[-] The following 1 user says Thank You to divingscubaboy for this post:
  • wandering
(05-08-2011, 05:10 AM)divingscubaboy Wrote:  Bearing in mind the temperatures we've been having I'm not surprised. When you turn the engine off, due to the lack of coolant pump operation and air flow through the rad you will get an increase in coolant temperature. This causes the fan to switch on, common on a lot of cars! I havent specifically looked at your model of bingo so don't know if the same applies but I wouldnt be overly concerned unless it does it in cooler temperatures. Is the temp gauge normally static? if so after turning the engine off wait in the vehicle until the fan cuts in and turn the ignition to position 2 but dont start. Watch the temp gauge and see what if anything happens.
thanks,
checked the coolant level this morning (doh!) and its a little low, so will be talking to the dealer. it was serviced so must have lost a fair bit of water over the week. i will also try the above.
thanks again,
If you're sure the level has dropped check to see whether the passenger footwell is damp i.e. the mat and underneath. The heater matrix's can weep. Not expensive for a new one (£30 ish) but a bit of a tit of a job!
  • wandering
(05-08-2011, 04:14 PM)divingscubaboy Wrote:  If you're sure the level has dropped check to see whether the passenger footwell is damp i.e. the mat and underneath. The heater matrix's can weep. Not expensive for a new one (£30 ish) but a bit of a tit of a job!
the footwell is dry (as far as I can tell) I called the dealer and they asked me to top up with water and measure how much is lost if it drops over the next few days. (its 5mm below minimum and the dealer sold it as serviced so it should be near maximum!) Still in warranty so it could be a tit of a job for the dealer, not me. The fan didn't come on this morning or this evening after my work/home trip....
Information
Fan running for a few minutes after you switch off is normal, particularly in warm weather.
[-] The following 1 user says Thank You to seamusgallen for this post:
  • wandering
(10-08-2011, 07:30 PM)seamusgallen Wrote:  Fan running for a few minutes after you switch off is normal, particularly in warm weather.
thanks for that.
the coolant level was below minimum, though, and I had to put in 600ml to bring it to the top. so far no change in coolant level (the pre sale service was not very good then!). the fan has not come on after stopping since, although the temperature has taken a dive too!!
I have 3 months to discover any problems under the warranty from the garage so am being a bit fussy at the mo.
not been on a long run so still not resolved.
Trip + Clock Help
Yesterday 10:01 PM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
Windscreen wipers banging
Yesterday 09:48 PM
Yesterday 09:43 PM
Yesterday 08:19 PM
Speed Camera Warnings
Last Post: StarFish
Yesterday 03:20 PM
Teletrac sat nav tracker
Last Post: ItsGreen
Yesterday 01:45 PM
» Replies: 20
New owner of a K9 2019
Yesterday 10:44 AM
Last Post: StarFish
Yesterday 06:33 AM
