Hello :wave:
Any advice is highly appreciated!
I have a x/2000 berlingo van with strange problems. The clocks/instrument panel was having fits. The fuel gauge was all over the place making a clicking sound and the revs and speedo made no movement at all also the mileage was reading zero's.
I bought some new clocks and fitted them today which has stopped the strange ticking sound but still no revs/speedo and mileage is still reading zero's.
A separate issue but maybe worth mentioning is I have no heater fan and central locking doesn't work
The indicators, lights, wipers and washers work, it starts and runs fine and has no other problems other then what I've mentioned. I've had the bsi out and checked for water damage, I checked all the earths, changed all the fuses for new ones and done the bsi reset a couple of times.
I have two keys but the one with buttons on doesn't turn the ignition and only opens and closes the front doors. This leads me to believe that its possibly had a new bsi,ecu and key at some point, is there any way to confirm this?
EDIT - In the drivers side footwell I found four damaged wires, looks as if someones had something fitted to them in the past. I've wrapped them in the yellow electrical tape but its the three connected to the green plug and the red one going in to the bsi. Perhaps this is connected to my problem. Any idea what the green plug is for?
[Image: 5413_zpsac01be9d.jpg]
