They could have been disabled by someone with DiagBox software, if so then you would need to use that software again to re enable it. You can buy the kit on eBay or online but it needs some steps to install and use. Not so easy for a beginner but there may be someone in your area who has it.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
The following 1 user says Thank You to Sol for this post:1 user says Thank You to Sol for this post • Lateralus
I have. 2015 van and the DRLs can be enabled and disabled in the centre display menus. Failing that I did see that they can be disabled in diagbox too.
Hello guys,and thanks for reply. Do you have maybe some manual how to check in centre display,i do have handbook,but didn't notice inside nothing regarding those lights..
If the sidelights or main lights are turned on, the DRL's are automatically deactivated. They can also be turned off using the configuration menu.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
It is also possible to configure the DRLs to stay on with the sidelights in diagbox. I tried it but I didn't like it
For your issue though - and I am assuming you have an RD45 radio and orange centre display - check the vehicle configuration settings in the van itself first.
Also seems they are disabled from new for non Nordic countries in the BSI configuration.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
27-01-2021, 08:45 PM (This post was last modified: 27-01-2021, 08:50 PM by Lateralus.)
I have audio system with bluetooth and orange display. And i have here on computer owner manual from 2016.,and it's different then yours,it doesn't say nothing about daytime lights.
(26-01-2021, 08:33 AM)Tree Wrote: Just click the vehicle settings in the menu - there is for sure a way to turn them off otherwise they just work as side lights
