Threads: 22
Thanks Received: 27 in 24 posts
Thanks Given: 31
12-09-2015, 07:11 PM
(This post was last modified: 12-09-2015, 07:16 PM by Hughzie.)
7 Sheets of 18mm 8' x 4' Ply..... Think I'll get them to cut it for me.
[Image: Cut%20list_zpsea7s7va9.jpg]
Thats £223.93 to cover an 8' wall in my garage with top and bottom cabinets then another £50 for a length of worktop.
16 Plate Berlingo Multispace XTR
Threads: 22
Thanks Given: 31
12-09-2015, 10:02 PM
(This post was last modified: 12-09-2015, 10:08 PM by Hughzie.)
(12-09-2015, 09:39 PM)geoff Wrote: Wow !!!! at 18mm a sheet I hope you have steel reinforced footings and a wall butress
Nah, Worse! Single layer brick with a load of heating pipes and cables!
Planning on studding it out with 2x4's first to provide a level frame to fix to. 18 has a lot more strength over a 4' span when loaded with the s**t I've got in that garage.
Plus 12mm tends to split when use a nail gun on it if you shoot like you piss.
Threads: 22
Thanks Given: 31
(12-09-2015, 09:29 PM)Jed Clampit Wrote: HA problem solved that's what i like to see
My Head hurts now, Not used a sheet of graph paper for going on 13 years now!
Threads: 22
Thanks Given: 31
I prefer a good screw instead of getting nailed.
