[Transmission] Very sloppy gear stick
2001 Berlingo van. 1.9 diesel
My berlingo van has a very slack feel to the gearstick which although does nothing to affect the gear changing
I find very annoying.
What is the possible cause of this and how easy is it to fix.
If you have any advice to help with this problem
Then please let me know
As I have the weekend off to fix this and a list of other bits on this old duffer
Its probably play and wear in the gear linkage to the box. Its a mix of rods, rose joint ball couplings, there are a few diagrams in threads on here to help you have a search. This is something like what you need but may not be the exact ones
http://www.ebay.co.uk/itm/CITROEN-BERLIN...xyOalTa3cR
Are we there yet????? Huh
[-] The following 1 user says Thank You to Tomcat3 for this post:
  • petesta
(23-10-2015, 01:43 PM)Tomcat3 Wrote:  Its probably play and wear in the gear linkage to the box. Its a mix of rods, rose joint ball couplings, there are a few diagrams in threads on here to help you have a search. This is something like what you need but may not be the exact ones
I will have a look
I will have a look
I did readread on thithis site that there is a nut under the gearstick on the underside of the van that can comealso.
se also
Changing the gearstick rods is easy- just remove the air cleaner first for easy access.
Heater Matrix replacement
Last Post: sirigonis
Today 06:27 PM
Last Post: Jakeblu
Today 02:39 PM
Last Post: Blakey
Today 02:30 PM
Today 11:29 AM
Trip + Clock Help
Today 11:25 AM
Speed Camera Warnings
Last Post: Desdinova
Today 09:49 AM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
Windscreen wipers banging
Yesterday 09:48 PM
Yesterday 08:19 PM
