Threads: 13
Thanks Received: 40 in 39 posts
Thanks Given: 61
(05-04-2021, 05:42 PM)Zion Wrote: If the alarm siren goes off when you open the door through the window, then you have one! If it ignores you, no alarm...
Then learn how to activate the deadlocks!
B9 (2016) 1.6 BlueHDi 100 Multispace XTR = Mine; B9 (2013) Enterprise 1.6 HDi Van = Hers.
Threads: 75
Thanks Received: 1,282 in 1,134 posts
Thanks Given: 223
162
Yep, press the lock button twice within two seconds, so as soon as the locks operate, you hear them lock and the indicators light up, press lock again as the indicators go off and they will stay on for two seconds, with a solid thump as the deadlock bolts engage. Lock....lock....done.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
Threads: 15
Thanks Received: 20 in 20 posts
8
"(don't press the locking button on the remote twice or the doors will deadlock and can't be opened even from the inside)"
"press the lock button twice within two seconds, so as soon as the locks operate, you hear them lock and the indicators light up, press lock again as the indicators go off and they will stay on for two seconds, with a solid thump as the deadlock bolts engage."
Can that just be explained for a second.
If the window is open and you deadlock it by pressing the remote twice, you can't then open the doors at all? Then what do you do?
But if you deadlock it with the window closed the doors will open as normal with the remote?
I'm a bit confused.
Now a 2019 K9 1.2 petrol.
Before a 2010 B9 1.6 HDi diesel.
Threads: 75
Thanks Given: 223
162
06-04-2021, 06:47 AM
(This post was last modified: 06-04-2021, 06:56 AM by Sol.)
If you deadlock the doors, they cannot be opened from the inside handle.....once deadlocked they can only be opened by unlocking again with the key blade or remote.....whether the windows are open or not.
My point was, put the window down, lock the car then open the door while it's locked by leaning in the window and pulling the inside handle. That will set the alarm off if it's armed.
As a test of the alarm, you're opening the door with the inside handle when the car is already locked. You can't do that with the deadlocks engaged....
** Note for peace of mind to van owners with no alarm, deadlock the doors when you park up unless someone is left sitting in the van of course. Once deadlocked, the doors can only be opened with the key or remote. Even if they break a window, there is no way to open any of the doors. Even from inside. The manual warns against deadlocking if you leave children / passengers in the vehicle as they will not be able to escape if there is a problem while you're away from the car or van.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
Threads: 15
8
Zion, thanks for the explanation. I get it now and it makes sense. I was just concerned there was some wrinkle that made it such that the doors were locked in such a way they couldn't be opened without specialised help. My interpretation of your posts was faulty.
Threads: 75
Thanks Given: 223
162
Ah no problem, you are very welcome!
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
Thanks Given: 6
So finally traced the draw down to the head unit. With the head unit plugged in it was fluctuating every 2 seconds between 5Ma and 150Ma, not a massive draw but certainly enough to keep draining the battery.
Fitted the headunit from my picasso and it dropped to a constant 5Ma but with the odd fluctuations of 16Ma which is much better.
I wouldn't have guessed the headunit was at fault but something clearly wasn't shutting off inside it.
