  • 29 Vote(s) - 3.41 Average
1.6HDi 16v manifold cowling
Howdy - just bought a 1.6HDi 16v Blingo - that big shiney metal cowling at the front of the engine (i think its over the manifold) has a snapped bracket at the top causing a very load rattle. Is this easily changeable? also where can i find a decent engine diagram for this model?
thanksConfusedalut:
I expect somebody will be along soon who can help, I only have the 2.0HDi so have no knowledge of your engine. In the meantime, you might like to have a look here:-
http://www.berlingoforum.co.uk/showthread.php?tid=815
[-] The following 1 user says Thank You to Coco for this post:
  • mrgreencar
Thanks Coco - i'm deeply jealous! I had a 2.0hdi until a month ago until I got rear ended on the M1 at 70mph! poor car was a mess!
mrgreencar, hope you came out of it OK. Sounds like a nasty crash.
Tom
(01-07-2011, 11:47 AM)3rensho Wrote:  mrgreencar, hope you came out of it OK. Sounds like a nasty crash.
Tom
It was! the rear end, sides, roof and floor were crumpled so far forward that only the drivers door would open! but me and my 2 year old daughter who was in the back walked out without a scratch! Good cars these Berlingos!!!
Both the cops and the rescue people reckoned the tow bar had taken alot of the impact and saved us- hense tow bar being fitted on new car asap!
I've seen them to snap at 16 & 14 in diagram 1.
They last one i repaired i removed the heatshield and pop riveted on a piece of 3mm material & drilled a 6.5mm hole rebolted on.
Hope it helps..:-)
[Image: berlingo16hdifrontheatshield.jpg]
[Image: berlingo16hdifrontheatshield2.jpg]
[-] The following 1 user says Thank You to Row for this post:
  • mrgreencar
Thanks Row thats REALLY helpful Smile
Have seen the loose cover cause a coolant leak from the oil cooler i think, cause by it rubbing against it. Try and get it fixed ASAP
[-] The following 1 user says Thank You to 800HDI for this post:
  • mrgreencar
Thanks - I will.
The problem is now fixed and very simply done. Took off the plastic pipe to the radiator which goes over the catalytic converter cowling. Just unscrew/unbolt and unpop. This gave full access to the broken bracket at the top of the cowling. A simple metal strap was cut/drilled and bent to shape and screwed/bolted to the existing screw and bolt holes in the cowling and the cowling securing point so no additional drilling required in to the cowling itself. The result is a very secure cowling which doesnt rattle anymore - YEEHAAAAAA:colors:
Thanks for all your help people - much appreciated
Attached Files Thumbnail(s)
Trip + Clock Help
Today 10:01 AM
Speed Camera Warnings
Last Post: Desdinova
Today 09:49 AM
New To Me Berlingo
Yesterday 09:53 PM
Partner Escape Front Struts
Yesterday 09:51 PM
Windscreen wipers banging
Yesterday 09:48 PM
Yesterday 09:43 PM
Yesterday 08:19 PM
Teletrac sat nav tracker
Last Post: ItsGreen
Yesterday 01:45 PM
» Replies: 20
New owner of a K9 2019
Yesterday 10:44 AM
Last Post: StarFish
Yesterday 06:33 AM
