Activation mirror heating
Wink
Hello guys!
I have today installed  button for heating mirrors,before it was just cover,but did removed it,and replaced it with button for heating,would like to know if is some activation needed with diagnostics or not? I do have electric adjustable mirrors,and i hear clicking noise in BSI when pushing the button,but mirrors are not getting warm.
Any help is appreciated,much obliged!
I believe that they only work when the outside temperature is below 4 degrees.
I may be wrong but that is the way the Skoda Octavia heated mirrors work.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
On older B9 i did have from 2011.,mirrors we're heating always when button was ON,regardless of temperature,also when was 13 deegres for example.
I dont know why you would need heated mirrors at 13 degrees but anything's possible with french cars.
If you have Diagbox you may be able to check if heated mirrors are present and if they are are they ticked to show that they are activated.
I dont know, but someone else who knows diabox better than me may be able to say if that's possible
(17-11-2021, 07:39 AM)brodfather11 Wrote:  I dont know why you would need heated mirrors at 13 degrees but anything's possible with french cars.
Gets rid of the dew on the mirrors in the morning - i used mine today and outside was around 9 degrees
And also,when is raining,it dries out mirrors quickly,for better rear view,i have berlingo as working van,without rear side windows,that means for me is important to have good sight what is happening behind me,so to speak.
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
