Threads: 63
Thanks Given: 410
16-05-2012, 06:15 PM
(This post was last modified: 16-05-2012, 06:18 PM by andy-womble.)
Bosch, Bosch or Bosch.....
Have a search round for my previous writings on the subject, bought a Bosch to replace a Tudor (original equipment) that was about to let me down
Threads: 5
Thanks Received: 4 in 4 posts
Thanks Given: 12
Thanks for that,just had a search and take notice on what's been written.
Looks like Bosch is the way to go then will have a look on line to see who is doing what and for how much.
Again thanks Andy ....
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
Your battery tray will take a larger battery should you wish. I have a Passat battery in mine!
It really spins the motor in the cold weather and the cost is not a lot different.
Threads: 76
Thanks Received: 332 in 275 posts
Thanks Given: 147
4
We ave an auto electrical place called Snowden,and the guy there would rather your repeat business than to rip you off so he will advise you rather than palm you off with what he has to shift.
If you can find somewhere like this rather than the "supermarket" outfits they would give you a bit more of their time.
Max AH for the biggest unit you can fit in the tray.
Watch the hight though -you dont want the bonnet with holes burned through!!
My vans manual actually recommends fitting a bigger battery for high drain users.
Ive had success with Hella batteries in the past.
Threads: 76
Thanks Given: 147
4
Lucas-Prince of Darkness
But Ive got Wipac on my AJS:eek:
Threads: 76
Thanks Given: 147
4
Or some googling..
Go to my Garage page -you will see my '61 AJS Model 14 bike -they were fitted with Wipac electrics rather than the usual Lucas "Prince of Darkness" kit on most other Brit bikes.
How far from Meriden would you be from
illyme:
Really difficult to get hold of it now and therefore most owners go for electronic ignition kits and 12-volt electrics.
