  • 6 Vote(s) - 3.83 Average
locker box
Just purchased a 2005 multispace and the hinge on lockerbox is broken,I know this is a common fault but has anyone other ideas than velcro
Well, I've been toying with the idea of using nylon straps pop riveted into place as restraints, likewise
using nylon webbing as a replacement hinge and fastening it with a magnetic catch or
using some of that magnetic strip you find in refrigerator door seals.
Trouble is that both my doors are still OK....so I'll have to wait until one breaks to try the scheme out!
Plastic welding is also a possibility.
Oh! Welcome Bryn!
I read of someone drilling a few holes and threading tie wraps through, even got some to match the material of the box so they didn't stand out as a bodge.
I need to investigate this as both of mine failed in the last couple of weeks. They weren't even being used, just failed !!
Too cold at the moment though.
  • bryn
(26-02-2013, 02:47 PM)bryn Wrote:  Just purchased a 2005 multispace and the hinge on lockerbox is broken,I know this is a common fault but has anyone other ideas than velcro
What's your problem with velcro? Used it on ours and holds it fine. Might be a pain if you use cupboard a lot, but easiest solution.
BTW, I tried supergluing the hinges. Didn't work, stuck my fingers together pretty well though!
anyone know where i might get one of these as ive one missing and it realy agrevates me
(28-02-2013, 06:47 PM)landcrab Wrote:  anyone know where i might get one of these as ive one missing and it realy agrevates me
Online breakers might be able to help you:
https://www.breakeryard.com/part-finder3
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
