  • 3 Vote(s) - 2 Average
[Engine] 1.9 D hard to start and runs poorly
Last week my 2004 1.9 Diesel started to “beep” and light the engine warning light every fifth minute when driving. When the days went by it also started to be gradually harder to start every morning. I had a suspicion that it might was the glow plugs or glow relay that was defective. Therefore I tested to restart the engine when it was hot (90,00C), but still, very hard to start. Yesterday it also started to run very poorly and noise...sounding like a gasoline car running on 3 cylinders…Any idea what the reason can be. I have read some threads about a so called “Advanced solenoid” mounted on the diesel pump. Could this be the problem? I have ordered a diagnostic tool to read out the fault code, but this has not arrived yet… Suggestions are appreciated.
Start simple first.Have you changed the fuel filter?Confusedalut:
(30-11-2013, 09:57 PM)ron Wrote:  Start simple first.Have you changed the fuel filter?Confusedalut:
I have looked at the diesel filter insert and it was very clean. I will also try to replace it when a can get the hold on a new one. But I don’t believe that should cause the engine warning light to go on??? Rolleyes Maybe somebody here knows?
M59 1.4 Petrol question
Today 02:27 PM
Cold Starting
Last Post: jboy012000
Yesterday 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
