  • 4 Vote(s) - 2.25 Average
Fuel filter change - step by step
Hi,
Today I did my first mini service on my 1.9D 2002 MK1 berlingo van, changing the oil, oil filter and air filter.
As the air filter was in a right old state I'm now thinking about changing the fuel filter.
Does anyone have a step by step guide with pictures on how to change the fuel filter?
Rob
I think it has a type of cable tie fixing.If so,unclip,replace filter,top up with diesel to save wrist ache later,fit top & bleed through.Sometimes when I have filled the housing brim full,they start without the need to bleed.:thumbsup:
  • GEORGEMXR
Great, thanks Ron.
How easy is it to bleed? If doesn't start.
Easy peasy. There is a bulb or a plunger which you pump until it's hard (ooer). Once there is resistance on the bulb then start the engine. Repeat as necessary until the engine runs. You may need to pump the thing whilst the engine is running if it splutters.
Malc
Stupid computer!
Thanks all, going to give it a go later.
[-] The following 1 user says Thank You to raw85 for this post:
  • tomski
Right, I've changed the fuel filter using a Hengst filter and it starts and drives fine BUT the old one was in the housing differently...the old one had the odd shaped seal facing up but when I tried to replace it with the new one facing the same way it was very very tight so I flipped it so the writing and round surface was facing up and it went straight in.
The housing leaked from the top so I fiddled with the rubber seal and tighten up by hand, all seems good.
I know the previous owner did his own servicing. Who has fitted the filter wrong me or him?
Did you check all old seals / o-rings were removed from the housing?
Yeah, nothing left in the the housing apart from diesel.
Yet another ABS fault
Yesterday 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
