Threads: 8
Thanks Given: 298
29
I've got you....I just thought the worst for a moment....
The following 1 user says Thank You to jj9 for this post:1 user says Thank You to jj9 for this post
• Arbe
Thanks Received: 2 in 2 posts
Thanks Given: 27
jj9 Do you remember the link you gave to the site selling shims. well it would seem after registering that they don't have any. After extensive searching I am unable to find any internet outlet that sells shims at a reasonable price, there was one that wanted £12.00 each which i thought was rather expensive. I am beginning to wonder of Citroen have stopped people selling shims and one must go to them.
Thanks Received: 22 in 20 posts
Thanks Given: 35
i have always ground a dip into the middle of the shim arbe, then placed the dip onto the valve stem
its very easy to do with a dremel or die grinder
The following 2 users say Thank You to frank for this post:2 users say Thank You to frank for this post
• Arbe, Art b
Threads: 8
Thanks Given: 298
29
Yeah as cancunia says we only use the catcar site for the diagrams and the part numbers.
Looking the shims up on the Citroen Service Box site the price of them seem to differ depending on the thickness, as there are quite a few different thickness's listed I chose a few at random and the prices ranged between £3.17 and £15.44.
I think I would be filing them down.
You need to register to use the Citroen service box site.
http://service.citroen.com/docprAC/
• Arbe
Thanks Given: 27
Thanks for your replies, more to delve into, its true there are loads of sites selling motorcycle shims and most are expensive. I lost a shim last night I thought I put it back under the cap when we left to go to bed, but looked this morning and it is missing well I presume anyway as I am sure it would not function well without it.
You may wonder why I am bothering with the internet for shims when I have a local dealer in la Chatre but that is 52 k there and back with no bus or train service. So long way to cycle, the French are not so good at responding to emails or letters and our French is not up to explaining.
I am curious about the main cause of this problem, can we call it a defect in the design or the materials used or is it something that occurs with this type of system.
Threads: 121
Thanks Given: 248
34
Another avenue maybe worth exploring, what diameter are the shims? Try searching for shims of that dia and see what comes up.
Thanks Given: 27
Well we make them 13.46/7. have tried but to no avail
Threads: 121
Thanks Given: 248
34
Maybe time for a bit of basic French in that case. Maybe take an old shim with you.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• Arbe
Thanks Given: 27
Has anyone got information to how much one can grind/sand shims down so as not to damage the case hardening ?
