  • 5 Vote(s) - 3.4 Average
near side window gone mad
Hi all my 08 Berlingo near side window started to make a terrible knocking and screaming noise on its way up last week.
I have taken the door card off and cant find anything wrong with it so I lubed the runners and cable pullies but it only made matters worse!
Now if I put the window more than 8” down it wont go back up without me taking the door card off and shoving it from the bottom at the same time as pressing the button to send the window up:censored:
It is looking to me like a internal fault in the motor causing it to jam what do you guys think?
Mine has a habit of jamming when going up, then going back down. Just put pressure on glass and that cured it...must be the seals.
[-] The following 1 user says Thank You to taxi for this post:
  • polar
My passenger side window makes a terrible squealing sound when it goes down or up but not if the window is wet.
I DO MISS MY BERLINGO Heart
HI guys my first thought was seals so I tried lubricating the them with wd40 but that gave no change in the problem.
But it cant have hurt doing that.
Window not sitting right, and rubbing ?
  • polar
Try some PTFE spray as WD40 is not really a lubricant for rubber
Another option is to use a long thin artist brush and some waterproof grease and try to get the grease in to the grooves of the window channels
With age, the rubber channels swell, gripping the glass tighter, hence the sticking and the noise
If the glass goes up and sticks it will put stress on the motor and window winder arms and will eventually cause them to bend, meaning the window will start to raise at a slant - it could even get to a point that the window will come off the runners completely and/or the motors will burn out
The only way to cure it completely is to fit new channel rubbers
[-] The following 1 user says Thank You to ntm1275 for this post:
  • polar
All good ideas guys when I get time ill check the seals, many thanks and keep the ideas coming.
  • taxi
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
