Hi All,
While driving today, the STOP warning light started flashing below my speedo. I did as i was told and stopped and turned off engine. started up after 5 mins and light was off so i carried on. 20 mins later happened again only this time by the the time i was able to stop the light was off. there were no other warning lights on and no problems for final hour of driving. Any ideas?
Cheers
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
Brake fluid may need a top-up.
Welcome to our forum!
04-01-2014, 06:41 PM
thanks for your speedy replies
Threads: 5
Thanks Received: 31 in 27 posts
Thanks Given: 2
check for fluid leaks at the base of the rear brake drum back plates and around the front calipers.
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Id say brake fluid, ive had this problem in the past.
I DO MISS MY BERLINGO
Threads: 5
Thanks Given: 2
If it's the fluid warning then the "!" in a red circle symbol should stay on as well. It does not have to drop much to trigger it. Look for damp on the inside of the rear tyres when it has been parked up overnight if the cylinders are leaking.
